////\LPINE F#1
FLC Addict :: BlaBla :: Le Bar
Page 1 sur 2 • Partagez •
Page 1 sur 2 • 1, 2
Re: ////\LPINE F#1
Ça sonne exactement comme un ss ou ya une légère différence ?
Re: ////\LPINE F#1
Tweek des filtres:
Vcap CuTF - Copper Foil Teflon Film Audio Capacitors
Application: Passive Crossover, Signal Coupling and Bypassing
Specifications:
•Lead material: 18 AWG solid core high purity OCC (Ohno Continuous Cast) copper with VH Audio’s AirLok insulation- a proprietary form of foamed/cellular Teflon with a Dieletric Coefficient of less than 1.45.
•Pure Teflon film dielectric. Cheaper forms of PTFE and FEP can be sourced (some cast, some skieved), and we tried them all. "You get what you pay for" was especially true when it comes to sourcing Teflon, based on our listening tests.
•Oxygen Free High Conductivity copper foil ( IACS of 101%). Our copper foil is rolled to extremely tight tolerances using state-of-the-art machinery and computerized electronics that constantly monitors the foil in real-time, and makes corrections while the material is being rolled. Even the rollers are machined in-house to ensure a smooth and consistent surface finish. This quality and precision is unmatched by any other company in the world.
•The copper foil is dead-soft annealed in an inert atmosphere, and treated with an anti-oxidant bath before being slit with blades that might rival the edge of a Hanzo sword.
•The copper foil is vacuum packed before undergoing our proprietary Cryogenic treatment process (below -300 degrees F) . We’re not talking about throwing some copper out in the Frozen Tundra overnight, but rather a $50,000+ state-of-the-art machine that uses custom profiles, and molecular kinetics to avoid any thermal shock to the material.
•Teflon film slitting is performed in-house, which means better control over environmental cleanliness, as well as frequent renewal of the slitting blades. You won't find a messy guy with a butterknife anywhere near our film.
•The winding process is performed in a clean, controlled environment on custom, internally-built manual winding machines. A select group of dedicated Master Winders (averaging over 14 years of experience) perform the winding operation with meticulous attention to every detail. Their pride of workmanship is is simply unmatched, anywhere.
• A new lead attachment technique was developed to maximize contact surface area with the winding and keep ESR astonishingly low, and extremely consistent from part to part.
•The core of the capacitor has been engineered to optimized the structural integrity of the winding, as well address internal resonances that may smear the audio signal.
•Dimensional ratios were carefully chosen for each value, based on listening tests specific to this construction type.
•Capacitor end fill was carefully evaluated, based on sonics, as well as its long term inertness and mechanical stability. The end fill process itself is quite lengthy and requires numerous steps that were perfected over years of experimentation.
•At several checkpoints during the construction process, every capacitor is tested to meet several critical electrical measurements and mechanical inspection criteria. No simple "batch testing" is performed- it's not good enough.
•An extensive, rigorous testing and burn-in protocol was developed to ensure the highest performance and reliability in the extreme environment found inside equipment that uses vacuum tubes. The sheer number and extensiveness of these electrical tests is well beyond industry standards.
Re: ////\LPINE F#1
freijojo a écrit:Ça sonne exactement comme un ss ou ya une légère différence ?
tu devrai plutot dire : qui a écouter les kit alpine ET du SS pour faire un CR ?
Re: ////\LPINE F#1
Oui et non si les écoute sont faite avec du matos différent dans une voiture différente ca vaut rien.
Faut trouver quelqu'un qui a testé les 2 dans la même caisse
Re: ////\LPINE F#1
sull a écrit:t'es pas dans la merde alors
On peut corsé la chose, en rajoutant les génésis
Re: ////\LPINE F#1
WAy, mais genesis c'est du dome pas du ring
Mais sur le fond je rejoins Sull, avec la manière !
Re: ////\LPINE F#1
laurent a écrit:WAy, mais genesis c'est du dome pas du ring
C'est un dome ca ?
Re: ////\LPINE F#1
Juste que sont dome a lui coute 519€ et que les rings ba 1099€
Donc bon on peut comprendre qu'il ce soit tourner vers les domes...
Re: ////\LPINE F#1
C'est pas tout a fait l'histoire, mais y'a de l'idée, par contre, il est ecoutable, il faut juste ce taper 1000 bornes ><
Re: ////\LPINE F#1
Un jour peut être... Et pourquoi que ca serait pas lui qui viendrait
lol bref revenons en au sujet ///\LPINE F#1
Re: ////\LPINE F#1
d'ailleur je peux faire le ménage, si tu veux et que tu cris pas au scandale !!!
Page 1 sur 2 • 1, 2
Page 1 sur 2
