-29%
Le deal à ne pas rater :
PC portable – MEDION 15,6″ FHD Intel i7 – 16 Go / 512Go (CDAV : ...
499.99 € 699.99 €
Beringher DCX 2496 Phase1
Beringher DCX 2496 Phase1 Empty Beringher DCX 2496 Phase1
Message  Admin Mar 23 Mar - 10:29
La bestiole.
Beringher DCX 2496 Phase1 415eeac80899ee10b9165bac89b26236
Adaptateur alimentation 12V.
Toute faite, toute belle et qui marche (testé, approuvé par RR).
Alim Vin 12-15v dcx2496
Beringher DCX 2496 Phase1 Alimdcxfait
Pas fait, sa sent le perchlo, ceci dit moins cher.
Beringher DCX 2496 Phase1 2496ps2
Schéma.
Beringher DCX 2496 Phase1 PSSchematic
Installation.
DEQ2496/DCX2496
1. Power off and unplug the processor, then remove the top cover. There are 3 screws on the top and 3 screws on the back.
2. Unplug the AC connection to the original power supply. You may need to work the glue loose before it will unplug easily.
3. Cut the 7 wires leading from the original power supply to the logic board, cutting in the middle to allow room to reconnect them later.
4. Unscrew the original power supply (4 black screws in the corners) and remove it from the enclosure.
5. Position the new 12V power supply in the enclosure so that the bottom doesn't contact any metal and the wires reach the cut wires from the logic board.
6. Using either screws or wire ties and anchors, affix the 12V power supply securely to the bottom of the processor enclosure, making sure the bottom of the board doesn't contact the metal surface of the enclosure.
7. Individually connect and insulate all 7 power supply wires. The wires coming from the logic board are, in order:
* +15V (Red) Red
* -15V (Blk) Black
* +9V (Blk) Orange
* AGND (Blk) Green
* DGND (Blk) Brown
* +5V (Blk) Yellow
* +3.3V (Blk) Blue
8. Install a 2A fuse in the fuse holder (if not already present)
9. Drill enclosure and install grommet for +12V/Gnd/Remote wires
Beringher DCX 2496 Phase1 2496internal2
XLR TO RCA.
Solution simplisme, un adaptateur XLR/RCA.
Beringher DCX 2496 Phase1 Na2fpmf-adaptateur-neutrik-xlr-rca-femelle-
Soit le kit qui vaut un bras de chez selectronic(pas de pub pour ces gens) soit un DiY qui prend pas beaucoup de temps.
La liste des composants est concise :
6 condensateurs 3,3nF polyester type LCC (dit le petit jaune),
6 condensateurs 4,7µF/50V Nichicon "Muse" ES non polarisés,
6 résistances 1K couche métal, tolérance ±1% (5% le fait aussi),
6 embases RCA femelles verticales pour circuit imprimé,
1 à 2 plaques d'essai à bandes (stripboard ou veroboard) selon largeur et quelques vis.
10€ de composant environ
* Monter la ou les nouvelles cartes selon ce schéma.
Beringher DCX 2496 Phase1 Shema%20rca
Schéma au format .rst( LochMaster)
Les composants du côté pistes et les embases RCA de l'autre. Prendre garde à respecter une distance raisonnable entre les composants et les pistes, afin d'éviter tout court-circuit.
* Déposer la carte de l'étage de sortie symétrique initial (20 vis et deux nappes).
Beringher DCX 2496 Phase1 Carte%20xlr
* Dessouder les 6 embases XLR femelles. Tresse ou pompe, au choix.
* Faire partir du trou laissé béant par le pin 1 de la première embase XLR (Output 1) un câble de masse qui ira vers la piste GND de la nouvelle carte.
Beringher DCX 2496 Phase1 Masse%20xlr
* Une fois la nappe séparée au cutter, c'est assez facile, comme c'est illustré cette photo
Beringher DCX 2496 Phase1 Cablage%20sorties
, isoler les fils 14, 16, 18, 20, 22 et 24 dans de la gaine rétractable.
* Remonter l'ancienne carte
* Monter la nouvelle carte, à l'aide d'écrous et boulons bien sentis, en lieu et place des XLR
Il faut ruser un peu : désépaissir le bas de la carte pour s'insérer dans le petit interstice et avoir du doigté pour visser les écrous du bas. A moins d'utiliser des vis perforantes, sans être sûr de la solidité dans de la bakélite (dans l'époxy pourquoi pas).
* Etablir les connexions
Beringher DCX 2496 Phase1 Exemplerca%20assym
en soudant les fils 13, 15, 17, 19, 21 et 23 à l'entrée respective des résistances n°1 à 6 de la nouvelle carte, directement sur la piste cuivrée
* Connectez le câble de masse.
On peut aussi remplacer les composants par de la qualité.
Entrée optique.
A venir...
https://flcaddict.1fr1.net
Beringher DCX 2496 Phase1 Empty Re: Beringher DCX 2496 Phase1
Message  freijojo Mer 16 Mar - 19:53
Il y aura une différence a l'écoute entre des câbles de modulations XLR/RCA et le tweak pour changer toutes les sortie XLR en RCA ?
Message  Admin Jeu 17 Mar - 16:57
Si on prend pas en compte la qualité des composant ou du câble utilisé , non.
Message  freijojo Jeu 17 Mar - 17:51
Ok, comme je doit refaire mes câbles, plus qu'a en profiter pour acheter 6 fiches XLR...
Ta put trouvé quelque chose de sympa pour l'entré optique?
Message  Admin Jeu 17 Mar - 18:57
pas pour l'instant mais tu peut nous pondre tes trouvaille photo et plan a l'appui
Message  freijojo Jeu 17 Mar - 20:27
Ba justement je trouve rien ca me rend fou!
Es ce pas plus intéressant de prendre un Ultramatch Pro src2496 (trouvable neuf a 125€) et d'entrés en optique dessus ressortir en XLR pour rerentré sur l'entré C du DCX ?
Par contre j'arrive pas a comprendre le tweak de cc+ sur le pros de Leguedin, pourquoi il a connecté les entrés A et B en XLR et une autre entré en optique?
Et pour son contrôle de volume comment il se débrouille ? Il agit pas sur les 6 sorties rca ? Il atténue a l'entré?
Message  pichon31 Lun 21 Mar - 19:21
Faut 2 fils pour faire l'entrée numérique en spdif direct sur le CS8416...ou un petit schéma à 3 sous pour le transformer en optique...
Le SRC t'apportera pas grand chose, hormis une sélection de sources et la capacité de sortir en aes/ebu pour rentrer direct dans le dcx...mais à tweaker le dcx, même si c'est pour rester en aes/ebu, c'est quand même pas un mal de schunter la carte d'origine...
Pour les sorties en xlr, chez selectro tu trouves les bornes rca qui se mettent en lieu et place des xlr d'origine. Pour info, neutrik fait les mêmes, mais la largeur différente fait qu'ils passent pas cote à cote...
Pour l'alim, je comprend pas l'interet de certaines tensions de sorties...à part si on cherche à alimenter les aop qui auront été remplacés par la carte de sortie passive...
La régul du 5v me semble un peu légére...mais le bruit de l'alim en bagnole...spa la priorité...
Pour le controle de volume, le kit chez AP est de bonne qualité, seul l'alim et la séparation des masses n'est pas idéale, mais pour le prix, difficile de faire mieux...Bon produit facile à réaliser mais avec quelques pièges...
C'est un produit qui se tweake relativement facilement aussi (régul 5v, condos + découplage, pga2311 en direct)...
Pour une bagnole, ca fait peut etre un peu gros...Reste plus que les solus de chez didden alors...ou du controleur de volume en numérique directement type merdian (pour un salon ça)...ou pour la caisse avoir la chance de toper la boiboite qui fait ca chez audiocontrol, mais quid du rendu de cette dernière ?
Message  Admin Lun 21 Mar - 20:01
On veut des liens, mais au mieux des schémas avec explication et tout et tout pichon ben alors on oubli les bonnes manières pig
Message  pichon31 Mar 22 Mar - 14:03
Les liens de quoi ???? Shocked
Ils sont tous déjà sur la page....
Pour les infos en fin de message, meridian, le 518; preampli num, super produit mais très rare, un peu capricieux avec certaines sources (du genre les hiface ou musiland, mais je lui en veux pas)...En gros, joue le role d'un SRC mais avec un dsp inside qui permet de traiter en entrée et en sortie quasi n'importe quel type de format num en gérant le dither et la longueur des mots, avec en plus le réglage de volume, et ça, c'est le top...
Le audiocontrol, MVC, pour la caisse, idem, super rare, mais semblerai pas pourri à la vue des specs pour de l'ana...
Message  freijojo Ven 6 Mai - 19:27
Message  pichon31 Jeu 12 Mai - 7:33
Si jamais il y a des intéressés, j'avais usiné en plexi noir ép 2 mm des supports pour 6 bornes RCA de sorties. Se mets en lieu et place des fiches XLR sans démonter la carte e/s d'origine.
Je peux éventuellement fournir les fiches rca avec....
me reste les résistances vishay DALE voire les condos evox RIFA ésotérique de la maurkitu pour faire le filtre HF et j'ai aussi un lot de 6 condos de 6.8µF 250V SCR pour faire le filtre passe-haut. Composants préconisés par T.Martin sur son site.
Avis aux intéressés
Message  Admin Jeu 12 Mai - 10:51
pichon31 a écrit:Si jamais il y a des intéressés, j'avais usiné en plexi noir ép 2 mm des supports pour 6 bornes RCA de sorties. Se mets en lieu et place des fiches XLR sans démonter la carte e/s d'origine.
Avis aux intéressés
jprend note
Message  freijojo Mer 16 Oct - 22:42
Salut.
Pour ceux que ça intéresse: Comment fonctionne egualisation du dcx :
Ceux qui veulent savoir ce que valent les cartes selectronic:
Le complément:
et ceux qu'il serait intéressant de faire:
Source
Message  sull Mer 16 Oct - 23:28
C'est bien beau toussa mais ça ne va pas remettre le H à la bonne place dans le titre du topic geek
https://flcaddict.1fr1.net/t261-xsara-vts-mise-a-jour-en-page-3
Message  freijojo Jeu 17 Oct - 20:04
Toujours sur la même source.
Mesures d'un dcx 2496 d'origine non tweaké:
